Show Command to Pull Interfaces IPs and Subnet Mask together in Brief
bravealikhan
Hi All,
I'm trying to pull all interfaces with IPs and subnet masks together, is there anyway we could do that from command line?
e.g. show ip int bri | exclude assi gives me list of interfaces and IPs, but I need to pull subnet mask aganist each IP/Interfaces.
2 Accepted Solutions
show ip interface | in line | add
For NXOS you will have to use regular regex. For example:
show run | include "(ip address|interface)"
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
7 Replies 7
balaji.bandi
If one of the output suggested not works for you, then you need to use some kind of Python script to pull the information and join back what you looking to report.
there are many example available in git have a look.
BB
you could also use:
Router#sh run | include interface | ip address
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.0
interface GigabitEthernet0/1
ip address 2.2.2.1 255.255.255.0
Thank you so much, this is really beautiful commands,
love Cisco community support!
This commend doesn't work on NXOS: version 9.3
show run | include interface | include ip address
show running-config interface | include address  (this command is working fine but it only pull ip with mask, which is good, but not interfaces name)
show run | include interface (this command only brings interfaces not not ips and mask)
% Invalid command at '^' marker.
Any suggestions will be apprecaited
Perfectly worked! Thank you
