CISCO 2960x Cisco Network Assistant
Dub34766
Hi, what software do I use to manage Cisco 2960x, I have logged in and changed the IP on Device Manager however I see the Cisco Network Assistant has been retired is it still possible to download off the Cisco Website.
Thanks in advance
Dub34766
thanks very much appreciated
6 Replies 6
balaji.bandi
yes CNA is retired still you like to use old Version you can use if you have in place.
if only one switch use GUI for the manangement - is that works.
BB
it is not available on the Cisco website anymore. You can use the link below...
https://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-network-assistant-for-windows-v6-3-4.html
Dub34766
I installed the file in the download link I sent you, it looks like it is malware. Don't install it ! Sorry about that...
thanks for flagging running scan now
tonigon536
Hello!
updated the switch cisco2960x - 48fpd-l to version c2960x-universalk9-mz.152-7.E10
after that, the switch did not start and there is such a problem:
CPU rev: B
Image passed digital signature verification
Board rev: 5
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff...|
Please tell me how to restore the switch
