02-27-2024 02:58 AM
Hi, what software do I use to manage Cisco 2960x, I have logged in and changed the IP on Device Manager however I see the Cisco Network Assistant has been retired is it still possible to download off the Cisco Website.
Thanks in advance
Solved! Go to Solution.
02-27-2024 06:41 AM
thanks very much appreciated
02-27-2024 03:01 AM
yes CNA is retired still you like to use old Version you can use if you have in place.
if only one switch use GUI for the manangement - is that works.
02-27-2024 03:12 AM
it is not available on the Cisco website anymore. You can use the link below...
02-27-2024 06:41 AM
02-27-2024 06:46 AM
I installed the file in the download link I sent you, it looks like it is malware. Don't install it ! Sorry about that...
02-27-2024 10:06 AM
06-15-2024 02:29 AM
Hello!
updated the switch cisco2960x - 48fpd-l to version c2960x-universalk9-mz.152-7.E10
after that, the switch did not start and there is such a problem:
CPU rev: B
Image passed digital signature verification
Board rev: 5
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff...|
Please tell me how to restore the switch
