07-02-2007 12:01 PM
How many can stack at a time and can they be used as Core, Distribution, and Access switches
07-02-2007 08:51 PM
9 3750 can be stacked at a time.
I guess it can be used for the above purpose.
depends on your network load thou if you concider it for the core layer.
Depends on the SFP you are installing.
hope that helps..
rate :-)
07-03-2007 11:29 AM
Can CISCO 3750G series switches be used as core, and or distribution switches?
07-05-2007 09:32 PM
hi ,
like i said it depends how much network load you are planning to impose on this switch .
it has a switching fabric of 32Gbps and stack forwarding of 38.7 Mbps
so you can use this switch were you want to but be sure to calculate your load while designing and recommending it.
better to ask a cisco design specialist.. :-)
