Cisco 3850 Default CPP
YusifAlexis22
Visitor
I am trying to implement a Control Plane Policy to my 3850 switch. Within this policy I want to restrict SSH access to the switch to only the loopback IP. I found documentation that the default CPP can't be removed. However, is it also not editable? I tried adding my configuration to the existing policy-map and ensured that my policy was at the top of the policy-map, but the traffic isn't being policed.
Configuartion:
ip access-list extended Restrict_SSH
deny tcp any host 1.1.1.1 eq 22
permit tcp any any eq 22
deny ip any any
class-map match-all SSH
match access-group name Restrict_SSH
policy-map system-cpp-policy
sequence-interval 10
5 class SSH
drop
control-plane
service-policy input system-cpp-policy
Mark Elsen
 - Check if this thread can help you :
               https://community.cisco.com/t5/network-management/restricting-telnet-ssh-access-to-loopback-address/td-p/1306161
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
