Cisco 3850 mgmt port no up
Ivan_Pashkin
Hi all
The management port on the 3850 switch does not rise
When I prescribe the port MGMT(gi0/0)  - no shutdown,
cisco display the message:
% HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
tell me what is the problem? configuration out of the box
6 Replies 6
balaji.bandi
Is this device part of Stack or standalone? ( to find some bugs around please post the below output :
show switch
show version
show run
BB
standalone, configuration in attachment
There are some bugs reported kind of symptoms but not particular to the model you mentioned, the version you running is cisco stable - but i see some bugs related to that version in our environment also.
moving to the next level may fix issues .-cat3k_caa-universalk9.16.12.04.SPA.bin. ( read the release notes before upgrading).
BB
marce1000
 - Probably a bug as can be seen from these bug reports , albeit for different platforms, but very indicative :
           https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu78125
           https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg64838
  M.
Javier Acuña
To verify port management first verify that the device is not on the stack.
Validate that the device connected to the port is turned on or discard the middle Cable
EmmaAlex80249
I did not received any conformation email?
