Cisco 3900 series
yasser38
  • Hello, I restored configuration on a cisco 3900 router series but due to an issue I can't login again since configuration include ssh, how can I reset the router without the need to login to the router, the router is cisco 3945
  • Please help me!
1. try using console connection. and if that also password protected which you dont know, go to step2.
2.https://www.cisco.com/c/en/us/support/docs/routers/2800-series-integrated-services-routers/112033-c2900-password-recovery-00.html - here you can bypass existing configuration at bootup process and do required changes and save.
Good luck
KB
Good luck
KB
It is not clear what the issue is or what about ssh is an issue. Perhaps telnet might be an option for accessing the router? I agree that access via console is a good option and as a last resort password recovery.
Rick
My problem is that the configuration I restored contains enable password and I don't have this password, so I cant login to my router,I just want to reset my router or bypass the configuration
Thanks for the clarification. In this case what you need is the password recovery procedure
Rick
