Showing results forĀ
Search instead forĀ
Did you mean:Ā
CISCO 4331
Good morning
I just received new router cisco 4331 and I setup  with one SM-X1T3 / E3 card and one NIM-2FXS / 4FXO. After the Router finish load I try to activate (enable) T3 card using this command: RT (config) # card type t3 1 0
The Router mark ^card unrecognized. Question I missing any other command.
6 Replies 6
saif musa
Level 4
Level 4
I think you need to activeate the card first without identifying port number. Try
Router(config)# card type t3 1
Then if it's accepted, it must been shown on running-config. After that you have to I'd identify the port number within that card.
Please inform me of updates.
Good morning
I try the command.  I change the card and the router and still with the same problem, but if I install T1 card the router accept the command. I upload a photo.
Good Morning I still working with my new Router and T3 card
And I find this message
%spa-3-msg_parse_failure: SIP1: iomd: failed to parse incoming message from sm-x-1t3/e3++
Curious if you are still having this problem? I have a Cisco 4451-X and using the same type of card and getting same exact error, any help would be appreciated
Same issue here, Cisco 4451 with a SM-X-1T3/E3 card showing this:
*Dec  7 20:25:21.941: %SPA-3-MSG_PARSE_FAILURE:iomd:  Failed to parse incoming message from SM-X-1T3/E3++= slot 1 subslot 0 board 0.
*Dec  7 20:25:21.942: %SPA_OIR-6-OFFLINECARD: SPA (SM-X-1T3/E3++=) offline in subslot 1/0
Router#show hw-module subslot all oir
Module        Model                Operational Status
subslot 0/0   ISR4451-X-4x1GE      ok
subslot 0/2   NIM-4MFT-T1/E1       ok
subslot 1/0   SM-X-1T3/E3++=       out of service(not allowed online)
subslot 2/0   SM-X-4X1G-1X10G      ok
amy.l.clay
I realize this is an older topic, but did anybody find a fix? Just happened for me on a 4351.
**** UPDATE **** It turned out to be a bad card. Tried a different card, no issues.
