Hi Folks
I'm looking to enable 2x2 MIMO on the cellular 4G/LTE interface which I believe this router should be able to do, however info is a bit scarce.
Its up and running at the moment, however removing the M1/DIV antenna does not slow down the connection which makes me think its not using it at all.
It looks to use a Sierra Wireless card MC7304 which should support MIMO
Any thoughts?
