cisco 6509-E Core Module
Muhammad Qasim
The network outage was caused by a hardware failure in the Core Module,
specifically the VS-SUP2T-10G with Factory ID VS-S2T-10G.
rommon 1 > set
PS1=rommon ! >
RJ45_CONSOLE=0
LOG_PREFIX_VERSION=1
?=0
CALL_HOME_DEBUG=00000000000
DIAG_DEBUG=000000000000
RANDOM_NUM=1849083401
BSI=0
BOOT=bootdisk:,1;
CONFIG_FILE=
BOOTLDR=
SLOTCACHE=cards;
DIAG_SUP_RST_COUNT=0
CRASHINFO=bootdisk:crashinfo_20230926-025419-KSA
RET_2_RTS=02:54:19 KSA Tue Sep 26 2023
RET_2_RCALTS=1695682472
rommon 4 >
rommon 4 > dir bootdisk:
bootdisk:%s72044-atafslib-m: Digitally Signed Release Software with key version A
Initializing ATA monitor library...
Directory of bootdisk:
2050    120105960 -rw-     s2t54-adventerprisek9-mz.SPA.151-2.SY3.bin
2      33554432  -rw-     sea_console.dat
9459    502845    -rw-     crashinfo_20230926-025419-KSA
12010    33554432  -rw-     sea_log.dat
rommon 5 > dir bootflash:
bad device name (Device not supported)
usage: dir <device>
is there possibility to recover back or Need to replace this module
Leo Laohoo
boot bootdisk:s2t54-adventerprisek9-mz.SPA.151-2.SY3.bin
Sep 26 2023 02:52:33.532 KSA: %LTL-2-LTL_PARITY_CHECK: LTL parity check request for 0x6E48 from slot 5.
Sep 26 2023 02:53:05.056 KSA: %LTL-2-LTL_PARITY_CHECK: LTL parity check request for 0x6E48 from slot 5.
Sep 26 2023 02:53:35.933 KSA: %LTL-2-LTL_PARITY_CHECK: LTL parity check request for 0x6E48 from slot 5.
Sep 26 2023 02:54:06.745 KSA: %LTL-2-LTL_PARITY_CHECK: LTL parity check request for 0x6E48 from slot 5.
Sep 25 22:54:14.257: %HA_EM-6-LOG: Mandatory.go_ltlmemconsty.tcl: GOLD EEM TCL policy for TestLtlFpoeMemoryConsistency
Sep 26 2023 02:54:14.693 KSA: %CONST_DIAG-STBY-2-HM_SUP_CRSH: Supervisor crashed due to unrecoverable errors, Reason: Failed TestLtlFpoeMemoryConsistency
Sep 26 2023 02:54:15.693 KSA: %SYS-STBY-3-LOGGER_FLUSHED: System was paused for 16w2d to ensure console debugging output.
Sep 26 2023 02:54:19.957 KSA: %PFREDUN-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
Sep 26 2023 02:54:19.957 KSA: %OIR-3-PWRCYCLE: Card in module 5, is being power-cycled 'Module reset'
Copy-n-paste the following outputs into a text file:
sh log system console file sea_console.dat
sh log system disk bootdisk:sea_log.dat
Attach the text file.
