Cisco 9300L Catalyst Switch - SNMP MIB Tag for Power Supply Status
jcsharp
I am using SNMP to read switch information from a Cisco 9300L Catalyst Switch and I am trying to figure out a direct reference tag/address that I can use to show the status of the two power supplies (redundant) as either On or Off. Currently I am able to use existing tags from the RFC1213-MIB file such as sysName (.1.3.6.1.2.1.1.5.0) to get the name of the switch, ipAdEntrAddr (.1.3.6.1.2.1.4.20.1.1[1]) to get the IP address of the switch, and ifAdminStatus-01 (.1.3.6.1.2.1.2.2.1.7.1) to ifAdminStatus-24 (.1.3.6.1.2.1.2.2.1.7.24) to get the status of the switch ports. I was wondering if there was something similar to these that I can use to see the status of the two power supplies in the supported MIB files which I found on this link: Cisco Catalyst 9300 Series Switches Data Sheet. While looking this up online I found ciscoEnvMonSupplyState (1.3.6.1.4.1.9.9.13.1.4.1.2)  and ciscoEnvMonSupplyStatusDescr (1.3.6.1.4.1.9.9.13.1.5.1.2) however I do not believe that these direct reference tags are supported by the Cisco 9300L Catalyst Switch.
marce1000
                    Did you try them ? What was the result ?
 M.
according to the documentation, the Catalyst 9300 supports the CISCO-ENVMON-MIB (linked below). The values you have posted are identical to those listed in the MIB. Can you get ANY of these values to work at all on the 9300 ?
http://www.circitor.fr/Mibs/Html/C/CISCO-ENVMON-MIB.php
