Cisco asa 5540 problems
andywilkie1981
I am having problems with using vpdn to connect to my isp when using the command vpdn group plusnet request dialout pppoe it says invalid error.
Please help
Thank You
Will upload config shortly
andywilkie1981
Here is my config
kali-ma# sh run
: Saved
: Serial Number: JMX1451L0Q3
: Hardware:   ASA5540, 2048 MB RAM, CPU Pentium 4 2000 MHz
ASA Version 9.1(7)16
hostname kali-ma
domain-name kali-ma2
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface GigabitEthernet0/0
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/1
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/1.100
 vlan 1
 nameif inside
 security-level 100
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/2
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/2.100
 vlan 2
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/3.100
 vlan 99
 nameif outside
 security-level 0
 no ip address
interface Management0/0
 nameif management
 security-level 0
ftp mode passive
dns server-group DefaultDNS
pager lines 24
mtu management 1500
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
http server enable
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
 no validation-usage
 crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate ca 18dad19e267de8bb4a2158cdcc6b3b4a
    308204d3 308203bb a0030201 02021018 dad19e26 7de8bb4a 2158cdcc 6b3b4a30
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d30
    36313130 38303030 3030305a 170d3336 30373136 32333539 35395a30 81ca310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313a30 38060355 040b1331 28632920 32303036 20566572 69536967
    6e2c2049 6e632e20 2d20466f 72206175 74686f72 697a6564 20757365 206f6e6c
    79314530 43060355 0403133c 56657269 5369676e 20436c61 73732033 20507562
    6c696320 5072696d 61727920 43657274 69666963 6174696f 6e204175 74686f72
    69747920 2d204735 30820122 300d0609 2a864886 f70d0101 01050003 82010f00
    3082010a 02820101 00af2408 08297a35 9e600caa e74b3b4e dc7cbc3c 451cbb2b
    e0fe2902 f95708a3 64851527 f5f1adc8 31895d22 e82aaaa6 42b38ff8 b955b7b1
    b74bb3fe 8f7e0757 ecef43db 66621561 cf600da4 d8def8e0 c362083d 5413eb49
    ca595485 26e52b8f 1b9febf5 a191c233 49d84363 6a524bd2 8fe87051 4dd18969
    7bc770f6 b3dc1274 db7b5d4b 56d396bf 1577a1b0 f4a225f2 af1c9267 18e5f406
    04ef90b9 e400e4dd 3ab519ff 02baf43c eee08beb 378becf4 d7acf2f6 f03dafdd
    75913319 1d1c40cb 74241921 93d914fe ac2a52c7 8fd50449 e48d6347 883c6983
    cbfe47bd 2b7e4fc5 95ae0e9d d4d143c0 6773e314 087ee53f 9f73b833 0acf5d3f
    3487968a ee53e825 15020301 0001a381 b23081af 300f0603 551d1301 01ff0405
    30030101 ff300e06 03551d0f 0101ff04 04030201 06306d06 082b0601 05050701
    0c046130 5fa15da0 5b305930 57305516 09696d61 67652f67 69663021 301f3007
    06052b0e 03021a04 148fe5d3 1a86ac8d 8e6bc3cf 806ad448 182c7b19 2e302516
    23687474 703a2f2f 6c6f676f 2e766572 69736967 6e2e636f 6d2f7673 6c6f676f
    2e676966 301d0603 551d0e04 1604147f d365a7c2 ddecbbf0 3009f343 39fa02af
    33313330 0d06092a 864886f7 0d010105 05000382 01010093 244a305f 62cfd81a
    982f3dea dc992dbd 77f6a579 2238ecc4 a7a07812 ad620e45 7064c5e7 97662d98
    097e5faf d6cc2865 f201aa08 1a47def9 f97c925a 0869200d d93e6d6e 3c0d6ed8
    e6069140 18b9f8c1 eddfdb41 aae09620 c9cd6415 3881c994 eea28429 0b136f8e
    db0cdd25 02dba48b 1944d241 7a05694a 584f60ca 7e826a0b 02aa2517 39b5db7f
    e784652a 958abd86 de5e8116 832d10cc defda882 2a6d281f 0d0bc4e5 e71a2619
    e1f4116f 10b595fc e7420532 dbce9d51 5e28b69e 85d35bef a57d4540 728eb70e
    6b0e06fb 33354871 b89d278b c4655f0d 86769c44 7af6955c f65d3208 33a454b6
    183f685c f2424a85 3854835f d1e82cf2 ac11d6a8 ed636a
  quit
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username admin password UKp00FF0j/hrjxRp encrypted
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:297855321b41c7b8aaa869a33c981441
: end
kali-ma#
