L2L Connection Flapping Between Interfaces
alowery.2.9872
Community Member
I want to start by apologizing as I am by no means a networking professional.
We have been having issues recently with our primary ISP, and have been trying to setup a connection to use as a failover.
We seem to be running into a problem with the l2l connection coming up and going down, and not being in a consistent state.
I've attached some of the debug files for reference(they may or may not help); it seems to occur even with one of the interfaces shutdown.
Can anyone point myself in the correct direction to get this resolved?
I have been referencing the CLI support document in the link:
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118962-configure-asa-00.html
Edit: asa1 is a 5512 running  9.6, asa2 is a 5512 running 9.2
Deepak Kumar
I went through the ASA2 debug message and found an issue "IKE COMMON DEBUG]Duplicate entry already in Tunnel Manager"
You can try with adding below commands at both ends:
crypto isakmp disconnect-notify
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
