Cisco Blade switch 3120G-S and LMS 2.6
phaddad
I'm trying to get device support for our new blade switches in Cisco LMS. I've installed the package CBS31x0(2.0), and it seems that CiscoView can correctly deal with the switches. However when I attempt to test the credentials, I get something like " device not supported" for all access methods. I'm sure my credentials are set up properly. Any advice would be greatly appreciated.
thanks,
Peter
Joe Clarke
You need to load the RME device package as well. Go to Common Services > Software Center > Device Update, and check the Common Services and Resource Manager Essentials boxes. Click the Check for Updates button. Download and install all available updates.
That said, this device may not be supported yet in RME 4.0.6. What is the sysObjectID of this switch?
I loaded all the available RME, CWCS device packages. No apparent difference in behavior.
The link below would indicate that this switch isn't supported in RME4.0.6.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0.5/device_support/table/RME405.html#wp286895
The sysObjectID is 1.3.6.1.4.1.9.1.948
thanks,
Peter
Correct. Support for this switch is scheduled for October of this year as part of the Incremental Device Update 21.0.
Peter
