12-18-2016 11:56 PM - edited 03-01-2019 06:04 PM
Hai ,
Cisco Catalyst 2960 series switch showing " Press Return to get started " when connect using Teraterm . using this message not possible to enter in switch settings .How to solve this issue or skip from this message . Error message has been uploaded . please refer it
Shyam
12-19-2016 04:09 AM
That's the right output when your consoled in and it boots up first , whats wrong , does nothing happen when you hit return ?
did you try putty instead
12-19-2016 10:07 PM
Hai ,
how i access user mode ?Actually i need to configure the switch . No commands or keys from keyboard are not working . in this not possible to enter any commands or anythings . i tried after resetting the switch many times . but it shows same message ' Press return to get started ' .
12-19-2016 04:09 AM
this is a standard message. Just press enter and you should see command prompt.
Do you have this issue also in for example PUTTY ?
12-19-2016 10:12 PM
Hai ,
I need to configure the switch . No commands or any key press are not working . it still showing the same message " Press return to get started " . How i access the user mode or configure the switch ?
i tried with PUTTY but same thing happen .
