Cisco Network Assistant Corrupt
brunellej
Support,
Recently, I downloaded the MAC version of CNA.   When I unzipped, and executed I receive a pop-up that says it's corrupted.
I have redownloaded and try older versions, but still no luck.   Am I missing a step to run under MAC OS?
John
bart.t
I was able to download 5.6.3, and update to 6.0 from within.
However, somehow, all devices I try to add give an 'unsupported' error message.
SOLVED:
It seems that macOS does not permit you to run .app files downloaded without valid certificates.  To fix the issue...
  1. Download a copy of Cisco Network Assistant
  2. Unzip the file
  3. In terminal enter the following
xattr -rc /[path-to-.app-directory/cna_mac_k9_5_89.1_en.app
 4.In the Mac Finder app, navigate to the unzipped file (directory actually) and double-click
Once you have completed these instructions, you will find the Network Assistant app installed in a Network Assistant directory under your home directory.
