Cisco catalyst 2960x bandwidth Utlilization
corne
On our Cisco 2960x switches the system health view shows no bandwidth utlizatition. Must i do something to see bandwidth usage?
Another thing is when i want to telnet from a switch CNA says that telnet is not installed? I want to make a SSh connection to switches, is this possible from within CNA?
corne
Another question that i have: 1 stack switch member has no connection line to the Core switch although it must be there (fiber) but in the Toplogy there is no line to the other switches (Core for example). This switch is a Cisco Catalyst 2960 X and is in a seperate building.
balaji.bandi
you did not provided the information, how your switch configured.
1. Is the switch configure Layer2 or Layer 3 mode ?
2. if you have NMS you can monitor the uplink with port with snmp
3. you need to enable ssh in vty to loging to switch ( due to security reason i would not recomend for telnet)
4. regarding core connected links, we need know how you configured what link going to core, so we can look the config and suggest better
BB
The 3 switches in stack are layer 2 switches. They have a fiber connection like the other switches who have visible connections.
What do you mean with:
SSH is enabled in the switches because i know connect with putty, but it would be nice to connect within CNA.
