ā07-16-2023 11:36 AM
i did a basic configuration of my cisco Catalyst
when i save the configuration or don't save the configuration, my enable password doesn't work.
i have not set anything but the hostname and a vlan up, i can't get passed this part?
any help why my enable password wouldn't work?
both are configured
not on a network yet
i also took a screen shot of the password's after i saved them.
ā07-16-2023 11:48 AM
You use local passowrd for telnet?
If yes change privilege level of username to level 1 and then check enable password.
Note:- be sure that you config enable password with
Enable password xxxx
Before do above step
ā07-16-2023 11:49 AM
Hi @dwtdlt3000
Share your running config and lets see if you missing something.
ā07-16-2023 11:50 AM
i can no longer get passed enable mode
ā07-16-2023 11:53 AM
Use console cable'
There is no password config I think'
If not help you then last resort is password recovery
ā07-16-2023 11:58 AM
i set a console password and a enable password, i made them both the same for now just to get use to setting up all of it.
ā07-16-2023 12:00 PM
Try console access to device and share config
ā07-16-2023 12:02 PM
>enable
Then add password (you previous config)
ā07-16-2023 12:04 PM
i took a screenshot of the password after i saved it.
i can only console in for now.
i don't have no dhcp or static ip set up.
i'm still in basic configure mode.
i only set up vlan and the 2 passwords.
ā07-16-2023 12:08 PM
The screenshots dont show anything' can you double check screenshots you share
ā07-16-2023 12:16 PM
the screenshot showed on my end, i'm not sure why you can't see it.
i'm just going to skip the secret cisco password and try and still figure out why it want work with the enable password.
ā07-16-2023 12:07 PM
i know how to recover or delete settings, but for some reason the Enable password never works again. even when i use the same passwords for both security features.
i'm thinking about just setting the enable password and leave the secret cisco password off.
ā07-16-2023 12:41 PM
What do you have for "aaa" config?
