cisco catalyst express 500 with PoE configure via web interface defaul
christiaanh2
Hi everyone I have a problem I want to configure my Cisco Catalyst Express 500 but I can't get into the web interface to configure the Switch does anyone know how to get into the web interface to configure the Switch I have four ip Phones
that I would like to use on this Switch because it has PoE
5 Replies 5
Mark Elsen
 - FYI : https://community.cisco.com/t5/networking-documents/how-to-configure-a-cisco-catalyst-express-500-series-switch/ta-p/3126702
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
does that IP address also apply to Belgium
balaji.bandi
Reset to factory default and test it, if this was not new.
the default IP same all over ( not related to region)
BB
I've followed the instructions but I still can't get into the Switch Interface could it be because I'm using Windows 11
are you able to ping the IP address of the switch ? follow the below guide?
https://community.cisco.com/kxiwq67737/attachments/kxiwq67737/6016-discussions-lan-switching-routing/60454/1/10034-500.pdf
BB
