Cisco CBS 350 problems
GPatrito
Hi everybody, I use a Cisco CBS 350 with a Merging Anubis and Dante Avio, both devices comunicate with AES/67 protocol.
The switch have just some months of life but at the startup of the system randomly I have this two problems.
- The Dante Avio need Poe and Poe is active on his port but the device is not powered, I have to upload the backup file and startup again the switch, then Poe is delivered correctly.
- The second one is:
Since that this are Audio Units they need a Master clock to work properly and sometimes I lost the clock, always at the startup.
The clock is delivered trough the Ethernet connections and a green light of the software tell me if the two machines are properly locked.
Frequently happen that the light switch between green and red providing to glitches in the audio.
I solve this with a reebot of the switch.
Have my switch some problem?
Thank you in advance.
Best
Hi George, thank you very much.
That was the solution.
Now the switch is very stable.
I did some stress test, as disconnect any device during the session and then connect again, the result is that all the system start again to work as nothing is happened.
Thank you!
Best Regards
