Cisco Prime infrastructure upgrade from 3.9 to 3.10
ndahemmy
hello everyone,
we have Cisco Prime Infrastructure 3.9 and we need to upgrade to 3.10. According to what i was reading the inline upgrade from 3.9 to 3.10 is not possible. You have to install 3.10 on a separate VM and restore backup of 3.9 after the installation is completed.
I am a bit confused! if anyone has done this before , kindly share with the steps from start to ends.
Thank you
Ruben Cocheno
@ndahemmy
Upgrade to Prime Infrastructure 3.10 from Prime Infrastructure 3.7.x, 3.8.x, or 3.9.x is not supported. You must take a backup of the Prime Infrastructure 3.7.x, 3.8.x, or 3.9.x server, deploy a fresh Prime Infrastructure 3.10 server, and restore that back up into the Prime Infrastructure 3.10 server.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10/release/notes/cisco_prime_infrastructure_3_10_release_notes.html
If this is VM - deploy new VM 3.10 and restore backup from 3.9
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10/admin/cisco_prime_infrastructure_3_10_admin_guide/backup_restore.html
  1. Is it an inline upgrade or new VM approach? I cant find any .tar.gz file in cisco.com>downloads  - new VM approach.
  2. If new VM, then do we have to use the same IP of old VM (after bringing down the old vm) or different IP address?  - you can build offline and do cutover with same IP address.
  3. If its new VM, does the DB restore will restore the IP address/hostname as well? - do basive network config and restore DB and MAPS will be good.
Note: some application data and telemetry can not move, so bare that in mind. also, check compatibility also.
Finally, make sure to upgrade to 3.10.1
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
ndahemmy
Thank you @Ruben Cocheno
I have a question, If my existing Prime 3.9 is currently installed on a physical server and i install 3.10 on a VM.
can't this cause issue when trying to restore 3.9 backup into 3.10 ?
Ruben Cocheno
@ndahemmy
I would raise that question with Cisco TAC, as might have implications with Licensing as well. I don't see any problem from a functionality point of view moving from Hardware to Virtual appliance as far as you size it properly.
ndahemmy
Heelo @Ruben Cocheno I am still on it.
Do you know any shell commands to check the Prime VM properties? i need to check the  existing server  to verify which one of the following configuration is deployed.
Thank you
Requirements
Express
Express-Plus
Standard
Professional
VMware Version
ESXi 6.0, 6.5, 6.7, or 7.0
Virtual CPUs
16
16
Memory (DRAM)
12 GB
16 GB
16 GB
24 GB
HDD Size
300 GB
600 GB
900 GB
1.2 TB
Throughput (Disk IOPS)
200 MB/s
200 MB/s
200 MB/s
320 MB/s
Minimum CPU Speed
2.29 GHz
2.29 GHz
2.29 GHz
2.29 GHz
