Reinstall or move Prime VM
RahmaSallm
We have a Cisco Prime 3.10 VM running in a VMware ESXi, 7.0.3 and NFS3 environment. We have to move it to a new environment with VMware ESXi, 7.0.3 and VMFS6.
What is the best way to do this and why? To move the VM or reinstall Prime in the new environment?
balaji.bandi
I suggest to build new VM on new Environment as fresh copy and take old PI  backup and restore on New PI and check all working.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10/admin/cisco_prime_infrastructure_3_10_admin_guide/backup_restore.html
If the IP is changed you may re-sync with devices - if you looking to use same IP then shutdown old PI and check on new PI all working as expected - before delete old VM of PI.
Note : always keep backup copy outside - until all working on new one do not delete that backup.
When you move - some time you may not get all assurance data to new Prime.
BB
balaji.bandi
BB
