09-03-2014 11:48 AM
Hi all,
When I check the output for the command "show environment temperature all" I see high temperatures reading, is this ok ??
router#show environment temperature all
module 1 outlet temperature: 53C
module 1 inlet temperature: 34C
module 2 outlet temperature: 57C
module 2 inlet temperature: 31C
module 2 device-1 temperature: 32C
module 2 device-2 temperature: 54C
module 3 outlet temperature: 55C
module 3 inlet temperature: 32C
module 3 device-1 temperature: 32C
module 3 device-2 temperature: 51C
module 4 outlet temperature: 50C
module 4 inlet temperature: 34C
module 5 outlet temperature: 33C
module 5 inlet temperature: 32C
module 5 device-1 temperature: 31C
module 5 device-2 temperature: 33C
module 6 outlet temperature: 38C
module 6 inlet temperature: 34C
module 6 device-1 temperature: 43C
module 6 device-2 temperature: 42C
module 6 asic-1 (SSO-1) temp: 33C
module 6 asic-2 (SSO-2) temp: 33C
module 6 asic-3 (SSO-3) temp: 33C
module 6 asic-4 (SSO-4) temp: 33C
module 6 asic-5 (SSA-1) temp: 33C
module 6 asic-6 (HYPERION-1) temp: 33C
module 6 RP outlet temperature: 35C
module 6 RP inlet temperature: 36C
module 6 EARL outlet temperature: 39C
module 6 EARL inlet temperature: 31C
09-04-2014 01:24 AM
the above output is correct , the above command will show you the "temprature " for all the modules ,rp and backplane ...
Router#show environment temperature ?
all selects all FRU-types
backplane specify backplane
earl specify earl <slot>
module specify module location
rp specify RP (MSFC) <slot>
vdb specify vdb <slot>
vtt specify VTT <number>
| Output modifiers
<cr>
If you want to see the "temp" for only RP then run the below command::
Router#show environment temperature rp ?
<1-4> module slot number
Thanks-
Afroz
***Ratings Encourages Contributors ***
09-04-2014 05:10 AM
Hi afrahmad, this command only gave me the temperature for module 6, and is the same than previous command
router#show environment temperature rp 1
router#show environment temperature rp 2
router#show environment temperature rp 3
router#show environment temperature rp 4
router#show environment temperature rp 5
router#show environment temperature rp 6
environmental alarms:
no alarms
backplane:
operating clock count: 2
fan-tray 1:
fan-tray 1 type: FAN-MOD-6SHS
fan-tray 1 mode: Auto
fan-tray 1 fan-fail: OK
clock 1:
clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
power-supply 1 fan-fail: OK
power-supply 1 power-input: 2 DC active
power-supply 1 power-output-mode: high
power-supply 1 incompatible with fan: OK
power-supply 1 power-output-fail: OK
power-supply 2:
power-supply 2 fan-fail: OK
power-supply 2 power-input: 2 DC active
power-supply 2 power-output-mode: high
power-supply 2 incompatible with fan: OK
power-supply 2 power-output-fail: OK
module 1:
module 1 power-output-fail: OK
module 1 outlet temperature: 52C
module 2:
module 2 power-output-fail: OK
module 2 outlet temperature: 56C
module 3:
module 3 power-output-fail: OK
module 4:
module 4 power-output-fail: OK
module 4 outlet temperature: 49C
module 4 inlet temperature: 33C
module 5:
module 5 power-output-fail: OK
module 6:
module 6 power-output-fail: OK
module 6 device-1 temperature: 42C
module 6 EARL inlet temperature: 30C
09-04-2014 05:14 AM
can you explain what you are looking for.. as the command is showing you the output the way is should be..
Thanks-
09-04-2014 05:37 AM
Hi afrahmad I want to know if the temp output is ok for all modules, because 53C seems to be high for the router...
