08-29-2011 06:35 AM
I use Ccp 2.5 every time and today i have got a problem with it . When i go to Security > Port to application mappings , i have got all ports , user-defined and system-defined (capture1). Next i go to Security > Firewall , If i try to edit or to create new rule , i can't choose system-defined service , i don't have the little "+" (capture2). I just can use user-defined services. If i return to Security > Port to application mappings , all the system-defined services disapear (capture3).
I check my firewall ( show ip port-map ) and i have my system-defined services.
If i discover again , the system-defined services return until i modify my firewall
I try different OS (Win Xp sp3 / Win 7 64bits) , different Java version , different IE version , different computer , re-install Ccp , nothing change.
My firewall have 12 weeks uptime and i don't made really great change , just use firewall setting .
May i do something wrong ? Is it a bug ?
I apologize for my very poor english
09-23-2011 02:19 AM
Did you attempt to clear both the Java and Browser cache and retry the operations?
09-27-2011 02:20 AM
I attempt , but the problem stay the same
I connect to the firewall with ssh client and surprise , the firewall say that i can't create more than 1023 class-map. I use another firewall and split my network in two and the problem is solved
Thanks anyway for your reply
