Cisco Configuration Professional 2.1
m.bavera
I have installed Cisco Cp on two different XP machines, and  I get the same error (Java ???) on both when I start the tool.
This is the error:
> org.hibernate.exception.GenericJDBCEException : Cannot open connection
> error
Has anyone seen this error and know if there is fix for it?
Thank you,
Marco
Nael Mohammad
Level 5
Level 5
A little late for this answer but you need to ensure that the JRE is not using a version greater than Java 6 update 17. If its higher, please remove newer version and downgrade as its not compatible.
chaitram
   The latest version Cisco CP is available for download at www.cisco.com/go/ciscocp. This problem should have been files in version 2.2. Could you try using CCP 2.2 pls?
