Cisco configuration professional (CCP) Java problem faultCode="Client.Error.MessageSend"
CSCO11812481
Hi :)
Every time I run CCP (as administrator) the application gives me the following errors (different code but the same two mistakes), I have tried with different versions of java, always marking adding the 127.0.0.1 as compatible in IE11 and adding as a secure site in java setting
can you help me?
Specifications:
Windows 8.1 64bit
Java 8.0.112 (Actually, previusly and try with versions 7.0.99 and 6.0.91)
[FaultEvent fault=[RPC Fault faultString="Send failed" CCP_issue.JPGCCP_issue_javaversion.JPGCCP_issue_sitesjava.JPGfaultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 500: url: 'http://127.0.0.1:8600/messagebroker/amf'"] messageId="8C38B59D-3F3E-12E2-0360-6C976C923EB4" type="fault" bubbles=false cancelable=true eventPhase=2]
[FaultEvent fault=[RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 500: url: 'http://127.0.0.1:8600/messagebroker/amf'"] messageId="6C3C1E68-A35D-17D1-5FF9-6C976D50C6E6" type="fault" bubbles=false cancelable=true eventPhase=2]
0 Replies 0
