Cisco configuration professional
Hi I downladed cisco configuration professional, but didn't found any installer from the zip file that I downloaded from cisco. The zip files only included some html files.
I read information from cisco configuration professional page that the file that I downloaded should be an installer for example: *.msi, or *.exe in my mind. Where is it?
Thank you
Totardo
Marvin Rhoads
You most likely downloaded the "express" package which is meant for installation on the device itself. the package for desktop installation is know as "pro" and the current release is 2.8.
You need the file name "cisco-config-pro-k9-pkg-2_8-en.zip".
It can be found here:
https://software.cisco.com/download/release.html?mdfid=281795035&softwareid=282159854&release=2.7
Marvin Rhoads
You are right thank you very much Sir!
