Cisco EEM triggered from IP SLA reaction configuration
l.hansen
I am trying to monitor the quality of a broadband radio, and change the path based on an IP SLA.  This is achieved by changing the running configuration of a router, (adding or removing configuration).
This issue im having is when the IP SLA detects abreach  of set threshold, the event manager running the cli commands, and when the IP SLA detects that the service is now working normally, the same commands are issued to the router. Where as im trying to have the Event Manager issue the opposite commands.
configuration thus far:
ip sla 911
udp-jitter 10.20.9.254 16384 source-ip 10.20.9.252
tos 40
threshold 50
timeout 150
frequency 30
ip sla schedule 911 life forever start-time now
ip sla reaction-configuration 911 react jitterAvg threshold-value 50 1 threshold-type average
ip sla reaction-configuration 911 react connectionLoss threshold-type immediate action-type trapAndTrigger
ip sla reaction-configuration 911 react packetLossDS threshold-value 5 1 threshold-type average
ip sla reaction-configuration 911 react packetLossSD threshold-value 5 1 threshold-type average
event manager applet EVENT_POOR_RADIO
event tag 1.0 ipsla operation-id 911 reaction-type connectionLoss
event tag 1.1 ipsla operation-id 911 reaction-type icpif
event tag 1.2 ipsla operation-id 911 reaction-type packetLossDS
event tag 1.3 ipsla operation-id 911 reaction-type packetLossSD
trigger
  correlate event 1.0 or event 1.1 or event 1.2 or event 1.3
  attribute tag 1.0 occurs 1
  attribute tag 1.1 occurs 1
  attribute tag 1.2 occurs 1
  attribute tag 1.3 occurs 1
action 1.0 cli command "enable"
action 1.1 cli command "configure term"
action 1.2 cli command "router ospf 20"
action 1.3 cli command "no network 10.40.9.0 0.0.0.127 area 0"
action 1.4 cli command "ip route 0.0.0.0 0.0.0.0 null0"
thoughts?
Joe Clarke
You need to check $_ipsla_condition:
action 1.3 if $_ipsla_condition eq "Occurred"
action 1.4  cli command "no network 10.40.9.0 0.0.0.127 area 0"
action 1.5  cli command "ip route 0.0.0.0 0.0.0.0 null0"
action 1.6 else
action 1.7  cli command "network 10.40.9.0 0.0.0.127 area 0"
action 1.8  cli command "no ip route 0.0.0.0 0.0.0.0 null0"
action 1.9 end
Joe Clarke
action 1.6 else
action 1.9 end
worked!
Thanks for your help Joseph
To Dampen the restoration to ive used the following:
event EVENT_POOR_RADIO
event tag 1.0 ipsla operation-id 911 reaction-type packetMIA
trigger
  correlate event 1.0 or event 1.2 or event 1.3
action 005   if $_ipsla_condition eq "Occurred"
action 010    cli command "enable"
action 015    cli command "configure term"
action 020    cli command "router ospf 20"
action 025    cli command "passive-interface GigabitEthernet0/0.10"
action 026    cli command "no event manager applet TIMER"
action 030   else
action 035    cli command "enable"
action 040    cli command "configure term"
action 045    cli command "event manager applet TIMER"
action 050    cli command "event timer countdown time 3600"
action 055    cli command "action 005 syslog msg $q PRIMARY PATH RESTORED$q"
action 060    cli command "action 010 cli command $q enable$q"
action 065    cli command "action 015 cli command $q configure term$q"
action 070    cli command "action 020 cli command $q router ospf 20 vrf SCADA$q"
action 075    cli command "action 025 cli command $q no passive-interface GigabitEthernet0/0.10$q"
action 080    cli command "action 030 cli command $q end$q"
action 085   end
