SNMP Walk Issue from LMS
Deben Bhattarai
Hello Experts,
I tried SNMP walk from LMS for below OIDS  but getting the error as attached..
MIB Name :- c2900PortDuplexState
OID's : 1.3.6.1.4.1.9.9.87.1.4.1.1.31
1.3.6.1.4.1.9.9.87.1.4.1.1.32
But while i do with OID 1.3.6.1.4.1.9.5.1.4.1.1.10 its showing the results.
My requirement is the pull the current negotiated Duplex status of interfaces, but with the OID 1.3.6.1.4.1.9.5.1.4.1.1.10 its only showing the configured values [ Auto , full or Half] not the negotiated duplex status if the port is in auto state. Please suggest.
Deben
2 Accepted Solutions
Rolf Fischer
Level 9
Level 9
Hi Deben,
here's a small list of OIDs for duplex for the Catalyst platforms I know and use:
1) 2900XL, 3500XL, 2900LRE, etc.: c2900PortDuplexState, c2900PortDuplexStatus
2) 2960, 3550, 3560, 3750, 4000, 6500: CISCO-STACK-MIB::portDuplex
3) 4500, 4900: EtherLike-MIB::dot3StatsDuplexStatus
For some reason I don't have access to the Object Navigator at the moment, so I can't provide the details.
I remember that one or more OIDs only work for active interfaces ("up"), just give it a try.
Hope that helps
Rolf
Vinod Arya
Topping up on Rolf's from cisco Object Navigator:
Object c2900PortDuplexState
OID 1.3.6.1.4.1.9.9.87.1.4.1.1.31
Type INTEGER
Permission read-write
Status current
Values 1 : fullduplex
2 : halfduplex
3 : autoNegotiate
MIB CISCO-C2900-MIB ;   -   View Supporting Images this link will generate a new window
Description "Set to fullduplex(1) to operate in full duplex mode, port
will allow simultaneous transmit and receive which can
double its bandwidth.
Set to halfduplex(2) to operate in half duplex mode.
Set to autoNegotiate(3) to allow the switch to negoti-
ate with the other end of the connection.
The status of duplex mode on a port is available with
c2900PortDuplexStatus object."
Object
OID 1.3.6.1.4.1.9.9.87.1.4.1.1.32
Type INTEGER
Permission read-only
Status current
2 : halfduplex
Description "The status of duplex mode on this port.
When linkbeat is not present, halfduplex is always
reported.
When linkbeat is present, the result of full duplex
auto-negotiation is reported if c2900PortDuplexState is
set to auto-negotiate, otherwise it reports fullduplex
if c2900PortDuplexState is set to fullduplex or
halfduplex if c2900PortDuplexState is set to
halfduplex."
Object portDuplex
Type INTEGER
Status current
Values 1 : half
2 : full
3 : disagree
4 : auto
MIB CISCO-STACK-MIB ;   -   View Supporting Images this link will generate a new window
Description "Indicates whether the port is operating in half-
duplex, full-duplex, disagree or auto negotiation
mode. If the port could not agree with the far end
on port duplex, the port will be in disagree(3)
mode."
Object dot3StatsDuplexStatus
OID 1.3.6.1.2.1.10.7.2.1.19
Type INTEGER
Status current
Values 1 : unknown
2 : halfDuplex
3 : fullDuplex
MIB EtherLike-MIB ;   -   View Supporting Images
Description "The current mode of operation of the MAC
entity. 'unknown' indicates that the current
duplex mode could not be determined.
Management control of the duplex mode is
accomplished through the MAU MIB. When
an interface does not support autonegotiation,
or when autonegotiation is not enabled, the
duplex mode is controlled using
ifMauDefaultType. When autonegotiation is
supported and enabled, duplex mode is controlled
using ifMauAutoNegAdvertisedBits. In either
case, the currently operating duplex mode is
reflected both in this object and in ifMauType.
Note that this object provides redundant
information with ifMauType. Normally, redundant
objects are discouraged. However, in this
instance, it allows a management application to
determine the duplex status of an interface
without having to know every possible value of
ifMauType. This was felt to be sufficiently
valuable to justify the redundancy."
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Rolf Fischer
Level 9
Level 9
Hi Deben,
Hope that helps
Rolf
Vinod Arya
Type INTEGER
Status current
2 : halfduplex
3 : autoNegotiate
Object
Type INTEGER
Status current
2 : halfduplex
reported.
halfduplex."
Object portDuplex
Type INTEGER
Status current
Values 1 : half
2 : full
3 : disagree
4 : auto
mode."
Type INTEGER
Status current
Values 1 : unknown
2 : halfDuplex
3 : fullDuplex
-Thanks
Thanks Guys.. Its really helped .. Now able to get the duplex as expected.
