Cisco Firepower 2130 no console access when connected to ISE
DSterling
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them? They are connected to a Cisco ISE device. When I disconnect from the ISE I regain console access.
-Software version: 7.0.5-72
-Configured with primary and secondary
-Base license
-Not using FMC
Can someone tell me how to get console access with out disconnecting the ISE?
Thank you,
Dave
As I know you can access via console to firepower only using local username not via AAA
So connect ISE and use local (admin) username and password to access
MHM
MHM,
I can't console using the local admin account while it's connected to the ISE, but when I disconnect from the ISE the local admin account works.
The local admin account is not in the Identities on the ISE, maybe it needs to be?
v/r Dave
do you I search for your post last week and couldnot find it
now it easily appear
are you config ISE user with priv 15 attribute ?
MHM
