Cisco IE4010 Powersupply different SNMP Index on same Model
Vie_adm
I tried to monitor the powersupply status of my new IE4010 Model. Therefore i used the SNMP OID 1.3.6.1.4.1.9.9.13.1.5.1.3 with the following outcome:
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.1042 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.1046 = INTEGER: 1
if i try this on a different switch (but exactly the same model and configuration) i get different Indexes:
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.1044 = INTEGER: 1
this would only make sense to me, if there where more than two possible supply sources available. Is that the case? Furthermore ist there a OID to get an overview for these interfaces like i get for the ethernet interfaces with "ifIndex"?
Its makes not much sense for me now.
Thank you!
Mark Elsen
 - To check if you have multiple power supplies use : show environment  , if so are both switches  running the same software version ?  If not the OID's can become different, the reason is then not always clear.  To get an overview have a full snmpwalk of http://www.circitor.fr/Mibs/Html/C/CISCO-ENVMON-MIB.php
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for your reply. Both switches do have redundant powersupplies and both switches running the same software version.
Thanks for the link - very helpful.
snmpwalk -v1 -c **** **** 1.3.6.1.4.1.9.9.13.1.5.1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1042 = STRING: "Sw1, PS1 Normal"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1044 = STRING: "Sw1, PS2 Normal"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.1042 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.1044 = INTEGER: 2
snmpwalk -v1 -c **** ***** 1.3.6.1.4.1.9.9.13.1.5.1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1046 = STRING: "Sw1, PS2 Normal"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.1046 = INTEGER: 2
I don´t quite get the different outcome. I think i let it be
 - Sometimes devices can have an (internal) different hardware revision leading to those subtle differences that you observe.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
