cisco ip phone not getting dhcp address
HI , I ask about this problem i have ip phones from cisco , Cucm ,Dhcp Server and Switch (Enable Poe in the Switch ) the problem is when i connect any Device Such as Computers in the Network The computer getting the ip address From Dhcp Server but When i Connect the ip Phone the phone is Working  but it Can't getting ip from dhcp Server. i erase all configuration in the phone but it cant getting ip from dhcp ?
Leo Laohoo
What is the configuration of the interface?  Is there a voice VLAN enabled?
If you're saying ALL your Cisco IP phones can't get an IP address, the question is:  Is the VLAN (and allowed VLANs) configured correctly?
Leo Laohoo
all ip phones can't get  ip address , i dont have any idea about configuration of switch because i am not configured it   ,  i think( Nothing to do with vlan) because when i connected any Computer or any thing the computer is getting the ip address.Leo Laohoo
Most Cisco wired IP phones (all the ones I have ever seen) have a port for the PC and one for the network. So the network switch sees two devices.
Cisco switches recognize the IP phone (via CDP) so they assign it to the voice VLAN. The PC gets assigned to the data (access) VLAN. The switch ports need a special setup for that on each interface. Something like:
switchport access vlan 10
switchport voice vlan 11
If that's missing, or if the DHCP scope serving the voice VLAN isn't setup with the necessary options for IP phones (most importantly the tftp server where the phone get's it's configuration from = CUCM or UC server - in addition to the basic IP address, netmask and gateway), then it won't work.
i Solved it , i reset the switch to default configuration .!
