07-20-2008 06:31 PM
Just a quick question on device discovery using CDP and SNMP v2.
Scenario:
Site A consist of the following cisco device
Router - 10.10.10.1
Sub-interface VLAN 1 - 10.1.1.254
Switch 1/Vlan 1: 10.1.1.1
Switch 2/Vlan 1: 10.1.1.2
Switch 3/Vlan 1: 10.1.1.3
INTERNET connection
Site B
Router - 20.20.20.1
Site A and B uses the same network IP address for the switch stack on VLAN 1 and is only separated by the router and the Internet. If the LMS server is on SITE X, is it possible to discover the switches on both Site A and B?
Site X has VPN connection to Site A and B via VPN.
Solved! Go to Solution.
07-20-2008 08:06 PM
This is not possible. Every device must have a unique management address in DCR. You can add the two routers to site X's LMS server, but not the switches at each site. They will not be properly managed.
07-20-2008 08:06 PM
