Cisco LMS 4: Monitoring router with multiple ospf processes
alex.dersch
Level 4
Level 4
i'd like to monitor the OSPF process of my MPLS routers by SNMP. I created templates for
ospfIfEvents
ospfNbrEvents
ospfSpfRuns
ospfNbrState
ospfAreaLsaCount
but when i configure the poller i believe the data i mixed up somehow. I for example i don't get all neighbor in the ospfNbrState.
i tried with snmp context configuration but i am not sure if this right what i did.
any suggestions?
regards
Alex
alex.dersch
Level 4
Level 4
I could solve the monitoring issue with snmp context configuration. I had to map each OSPF process to a snmp community. So i could retrieve data for each OPSF process. My issue now is how to add multiple communities to an LMS controlled device.
As far as i know, LMS support only one RO community per device.
regards
alex
