Cisco Mibs with traps defined
srego4
Level 2
Level 2
Can anyone let me know (or provide a link) for some of the cisco mibs (with traps defined in them) for cisco 3845 routers and 6500's.
thks
perhaps this link has what you are looking for:
ftp://ftp.cisco.com/pub/mibs/traps/
9 Replies 9
Lucien Avramov
Level 10
Level 10
the command show snmp mib on IOS should provide you with this information.
thks. However, is there any way I can find out or single out the ones which have 'traps defined' in them, without having to open / read them ?
the command : snmp-server enable traps ? will list you all the possible traps for snmp to be sent from the device
hi,
sorry i prob. am not making myself clear.
What I am trying to do is to import mibs into a management software trap manager. However, I only need / want the mibs that already have the traps defined in them - that way my mangement software will be able to translate the traps into meaningful messages.
If you already getting traps you can search by OID in which MIB they're defined with http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
thks bilousand,
i had tried that link. but i'll try it again.
BINGO!!
thanks mermel.
