Cisco Network Assistant 6.34 Runtime Error on a Macbook Pro
lennons
I installed the 6.3 cna on my macbook pro running OS 10.14.2 .  Every-time I start the application I get a Error in Runtime.exec
Has anybody ran into this?
6 Replies 6
marce1000
 - What is the error ?
M.
In Startup Error window, "Error in Runtime.exec"
Did you resolve this issue? I'm getting it too
Sorry, it's been a while, but I don't believe I did.  My workaround was to install it in a Windows VM and run it from there.
sudo su
java -jar Cisco_Network_Assistant/Launcher.jar
Having this problem with MacOS 11.0 Big Sur, does other people also have problems booting Cisco Network Assistant? I'm also wondering if there are other applications to manage Cisco Switches other than CLI and DNA
