Cisco Network Assistant - CCO login not working
wildbluesky
CNA 5.8(1)
32 devices
When I first launch the application, it promots for CCO login information, but then tells me the username or password is invalid.  I reset it once, and it appeared to work.  Next time I launched the application though, it gave me the same login error and did not store any of the device credentials.  This is a new install of CNA and it just has one community setup on it now.  I've tried 2 different CCO accounts and they both give the same login failure.  I know the passwords I'm using are correct though.
23 Replies 23
singhaam007
Level 3
Level 3
hello,
contact Cisco
web-help@cisco.com
thanks
I'll contact them, but it doesn't seem like an account problem - if I check for updates within the application, it asks for login information and that works ok (tells me I have most current version) it's just if I try to save credentials or enable "Product Improvement" it says 'the username or password is invalid'
  We have found certification issue running on CNA , Support team is working on updating the certificate. Hopefully, it starts working in next 48 hours.
Note: It will impact only on CCO login and Inventory upload.
Thank you
Srikanth Achanta
Has this been resolved?  I'm still having problems logging in to save credentials.
we have the same trouble, the cco login works with the webpage and the application update menu but it doesnt work with the "encrypt and store device credentials" menu in the cna prefs.!
This is since the last cna update!
Sorry for the brevity ...
regards, andy from germany
Hi Seth Jones,
    Issue has not been resolved yet. Hopefully it should work by early next week.
Thank you
Srikanth Achanta
it works now, I guess took a few tries
AtchisonC
I'm having exact same issue. CNA fires up but if I select the "encrypt and store ..." and attempt to login it states I've an invalid Login|password which I've verified are good.
Atchison
Hi All,
   It started working.
  Could you please let me know your comment on this.
Thank you
Srikanth Achanta
it works!
thank you Srikanth.
regards,
Andy Weber
AtchisonC
My login & ID were accepted!
Working for me now as well - thank you!
Good morning,
I have just installed CNA again after deinstalling it. When I initially launch CNA it asks me for my CCO credentials. Apparantly they work becuase I am able to post in this forum however when I click the "OK" button I recieve the following:
Can assistance be provided by anyone?
Any help would be greatly appreciated.
-Micah
Hi Micah,
       It working now.
Could you please let me know your comments on this.
Thank you
Srikanth Achanta
