how to configure sFlow and NetFlow in Cisco switch SG250
ciscoflow
I've Cisco SG250X-24P 24-Port Gigabit PoE Smart Switch with 10G U
How can I configure sFlow and NetFlow on it?
According to the release notes from April 2016, sFlow should be supported (https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf_sg250/release_notes/R_2_1_0_RN.pdf)
I also tried the commands from sflow.org for this switch but unsuccessful (https://blog.sflow.com/search/label/configure)
Thanks!!!
Deepak Kumar
What is the firmware version and what is hardware model?
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thanks Deepak for your urgent reply :)
It is SG250X-24P 24-Port Gigabit PoE Smart Switch with 10G U
Manufactured in January 2019, and software version is 2.4
I've tried command feature sflow from terminal but unsuccessful
Thanks!
