Cisco Network Assistant gui is erratic 5.6.3
ljramos
Cisco Network Assistant opens up fine, but i have to click and/or mouseover the center to be able to see the pop-up to connet to a device or comunity
it is strange
OS Name:                   Microsoft Windows XP Professional
OS Version:                5.1.2600 Service Pack 3 Build 2600
OS Manufacturer:           Microsoft Corporation
OS Configuration:          Standalone Workstation
OS Build Type:             Uniprocessor Free
System Manufacturer:       Acer
System Model:              TravelMate 290
System type:               X86-based PC
Processor(s):              1 Processor(s) Installed. x86 Family 6 Model 9 Stepping 5 GenuineIntel ~1 298 Mhz
Total Physical Memory:     2,031 MB
Available Physical Memory: 745 MB
Virtual Memory: Max Size:  2,048 MB
Virtual Memory: Available: 1,997 MB
Virtual Memory: In Use:    51 MB
thanks
mdeprete
Hi Luis,
Few questions :
- is it the same on all machines you tested CNA on ?
- is this an upgrade from a previous (and working) version ?
- is it the English version of Windows, or a localized one ?
Marc
