Cisco Network Assistant Problems
Jacobo Freireich
Community Member
I get this error when installing it on Windows 7
ERROR:POSTINSTALLCUSTOMACTIONS
javaPathString "C:\Program Files\Cisco Systems\Cisco Network Assistant\packages\runtime-1.51\bin\javaw"
  rootDirPropertyString -DROOTDIR="C:\Program Files\Cisco Systems\Cisco Network Assistant"
  classPathPropertyString -classpath
  classPathValueString "C:\Program Files\Cisco Systems\Cisco Network Assistant\packages\startup-1.51\cmdsvc.jar;packages\startup-1.51\cna_boot.jar;packages\startup-1.51\cna_launcher.jar;packages\i18n-1.51\i18n.jar"
  mergeClassValueString com.cisco.cpnm.boot.internal.Merge
Cannot run program ""C:\Program" (in directory "C:\Program Files\Cisco Systems\Cisco Network Assistant"): CreateProcess error=2, The system cannot find the file specified
Is there something I could do to fix this ?
Thanks.
9 Replies 9
ngoldwat
Level 9
Level 9
Some questions:
What version are you running?
Are you joined to a domain?
Are you installing as an administrator?
Does the installer have the required privileges?
Are there any Windows Event Logs?
Here are the Release Notes for version 5.
I just installed version 5.8 (5)  with no issues on Windows 7 Ultimate.
You can navigate to Help > Support Information > Troubleshooting Log for more information.
On mine:
======== System Properties ========
java.runtime.name=Java(TM) SE Runtime Environment
sun.boot.library.path=C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant\packages\runtime-1.51\bin
java.vm.version=10.0-b19
commandline.arguments=C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant\utilities\prelaunch\prelaunch.exe
java.vm.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
path.separator=;
java.vm.name=Java HotSpot(TM) Client VM
file.encoding.pkg=sun.io
sun.java.launcher=SUN_STANDARD
user.country=US
sun.os.patch.level=Service Pack 1
javax.accessibility.screen_magnifier_present=true
java.vm.specification.name=Java Virtual Machine Specification
user.dir=C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant
java.runtime.version=1.6.0_05-b13
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
ROOTDIR=C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant
java.endorsed.dirs=C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant\packages\runtime-1.51\lib\endorsed
os.arch=x86
Unfortunately, I have the same problem.
On Windows 7 64-bit Cisco Network Assistant installed with no problem.
But on virtual machine Windows 2008R2 Enterprise 64bit it's impossible.
javaPathString "C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant\packages\runtime-1.53\bin\javaw"
  rootDirPropertyString -DROOTDIR="C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant"
  jvmEnvString -Xms256m -Xmx1024m
  classPathValueString "C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant\packages\startup-1.53\cmdsvc.jar;packages\startup-1.53\cna_boot.jar;packages\startup-1.53\cna_launcher.jar;packages\i18n-1.53\i18n.jar"
Cannot run program ""C:\Program" (in directory "C:\Program Files (x86)\Cisco Systems\Cisco Network Assistant"): CreateProcess error=2, The system cannot find the file specified
Has anyone had a similar problem and solved it?
Anyone ?
Jacobo Freireich
Community Member
1 Disable the firewall
2 Disable the antivirus software
3 reinstall as administrator
it might help
Thank you for your response.
Unfortunately, without firewall - did not work (no AV installed)
javaPathString "C:\Cisco\Cisco Network Assistant\packages\runtime-1.56\bin\javaw"
  rootDirPropertyString -DROOTDIR="C:\Cisco\Cisco Network Assistant"
  classPathValueString "C:\Cisco\Cisco Network Assistant\packages\startup-1.56\cmdsvc.jar;packages\startup-1.56\cna_boot.jar;packages\startup-1.56\cna_launcher.jar;packages\i18n-1.56\i18n.jar"
Cannot run program ""C:\Cisco\Cisco" (in directory "C:\Cisco\Cisco Network Assistant"): CreateProcess error=2, The system cannot find the file specified
Harald-Norvik
I solved my issues with CNA and installer / java issues by installing it in a directory that is not under Program Files.
The directory I installed into was C:\CISCO and everything came up nicely.
I think many of these issues are cause by Windows 7 UAC which prohibits writing to any of the Program Files subdirectories without administrator access.
Hope this solves the issue for some of you - at least it solved my "Cannot create Java Virtual machine" on my system.
Harald
It's cool. I disable UAC and setup CNA in the directory C:\CISCO. Thanks.
I think in this case is about the long path, because I disabled the UAC and install it on a large path with spaces, and its don´t work.
Then, I enable the UAC again and install on a short Path like D:\Cisco and it´s works.
For this, I think there is a problem with the Windows Long Paths.
Best Regards
