Cisco Network Assistant v6.2 - Problem Creating VLANs
dale.magnant
It appears there is a problem with the creation of VLANs using Cisco Network Assistant v6.2 and the following Switch / IOS combinations;
WS-C2960CX-8PC-L                         15.2(3)E1-UniversalK9
WS-C2960X-24TS-L                          15.2(2)E1-UniversalK9
For example, in Front Panel view, if I …
  • Select the switch
  • Click the VLANs icon
  • Select the Configure VLANs tab of the VLANs window
  • Select Create (enter VLAN info)
  • Click Apply
  • Click OK
Everything will seem to have been performed properly. However, if I then go back to the VLAN window, the just created VLAN will not appear.  This seems to be very repeatable with the above switch / IOS combinations.  If I telnet to the switch and create the VLAN via the command line, it will then appear in the VLAN window and will remain.
Interestingly enough, it appears that a WS-C2960-24TC-L running IOS version 15.0(2)EX5-UniversalK9 does not have this problem – VLANs created with CNA will persist after creation rather than disappearing.
Three questions:
  1. Is this a known flaw in Cisco Network Assistant v6.2?
  2. Will this likely be remedied in the next version (6.3)?
  3. What is the latest word on a release date for 6.3?
Thank You,
Dale M.
0 Replies 0
