Qos on switches
George Phillips
We have an existing Cisco network and I support 1500+ IP phones that are on it. None of our switches ever had QoS enabled. Since a recent network design upgrade we have been experiencing call quality issues both internally and externally.
Can anyone point me to what might be causing our new issues?
Thank you,
Philip D'Ath
It would be a million things, but you should start with Cisco's recommend configurations.
On ports that go to other Cisco switches you should use:
interface Gigabit a/b/c
 macro apply cisco-switch
On ports that go to Cisco routers you should use:
 macro apply cisco-router
On ports that go to phones you should use:
 macro apply cisco-phone
