Cisco Network Assistant
mark_Bayliss
Hey Everyone,
I created a cluster on our Catalyst 3550 switch. We have around 30 2950-24T switches across our network. Unfortunately I can only have upto 16 switches in a cluster. Does anyone know the best way to over come this so I can have all my 30 switches under the one cluster?
Cheers,
Mark
wong34539
Level 6
Level 6
Make sure that all of the switches are connected using those ports in the same management VLAN. Access to all the cluster management facilities is through the command switch IP address. The command switch IP address always belongs to the management VLAN, which is VLAN1 by default.
All switches within the switch cluster must have the same management VLAN as the command switch.
