Cisco network assistant
Dear All,
I'm planning to implement couple of 3750-E and 2 4507R-E switches. is it possible to use CNA latest version with these switches.
Binoy
crow930us
Level 6
Level 6
It looks like both of them are supported with version 5. Here is the Data sheet for the Cisco Network Assistant: http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps5931/product_data_sheet0900aecd8068820a.html
hth
Lucien Avramov
Level 11
Level 11
Yes it is possible. Make sure you are following the configuration guide.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp699844
Click on Devices Supported on this page to see your devices. Ver. 5.4 should work for you.
Good luck!
