Cisco network assistant????
darren849
I have to rebuild the PC that my Cisco network assistant lives on. How do I do a back up and a restore? Is there some kind if Config file or data base I need to copy. I don't want to have to recreate all the community's again
Marvin Rhoads
If you look on the existing PC, there should be a hidden directory in your user folder called .networkassistant (viewable by going into Windows Explorer menu and choosing Organize > Folder and Search Options > View > Advanced Settings and click the radio button to "show hidden files folders and drives").
That folder has a subfolder called "communities". It contains a set of XML files with the community info in them. You can copy that over to the new machine.
I'm not positive if the password folder can be copied over similarly.
