I'm configuring cisco 1040 Sensors on a Cisco Prime Collaboration Manager version 9.0. I follow the guide from configuration guide, but all sensors that I configure are on Waiting status on Registered With Field. On the sensor web server, the status infor shows "not communicating with receiver". All IP address are OK and on Prime server I can see with tcpdump that de Sensor are sending packets by tcp port 2000, but ony see SYNC packets:
[root@TLF-PRIME-UCX ~]# tcpdump -n -i eth0 host 192.168.64.8
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
13:35:44.124167 IP 192.168.64.8.1040 > 192.168.63.11.2000: S 602652919:602652919(0) win 5840 <mss 1460,sackOK,timestamp 62095 0,nop,wscale 0>
13:36:32.124403 IP 192.168.64.8.1040 > 192.168.63.11.2000: S 602652919:602652919(0) win 5840 <mss 1460,sackOK,timestamp 66895 0,nop,wscale 0>
13:38:11.135074 IP 192.168.64.8.1041 > 192.168.63.11.2000: S 818224144:818224144(0) win 5840 <mss 1460,sackOK,timestamp 76796 0,nop,wscale 0>
13:38:14.134812 IP 192.168.64.8.1041 > 192.168.63.11.2000: S 818224144:818224144(0) win 5840 <mss 1460,sackOK,timestamp 77096 0,nop,wscale 0>
13:38:20.134840 IP 192.168.64.8.1041 > 192.168.63.11.2000: S 818224144:818224144(0) win 5840 <mss 1460,sackOK,timestamp 77696 0,nop,wscale 0>
13:38:32.134888 IP 192.168.64.8.1041 > 192.168.63.11.2000: S 818224144:818224144(0) win 5840 <mss 1460,sackOK,timestamp 78896 0,nop,wscale 0>
