Cisco Network Assistant
ktrahan67
Community Member
How does CNA discover specifically? Does it use the Device manager and if so what format HTTP or HTTPS? I cannot discover 2960x's on my network unless it is directly connected to another device, but the IS tech said he disabled Device Manager. If it uses HTTPS I can convince them to re-enable this setting for switch manage.
I am using the latest update.
0 Replies 0
