Make sure that all of the switches are connected using those ports in the same management VLAN. Access to all the cluster management facilities is through the command switch IP address. The command switch IP address always belongs to the management VLAN, which is VLAN1 by default.
All switches within the switch cluster must have the same management VLAN as the command switch.
