Cisco Networking Assistant Configuration Archive
airborne1128
Is there a way to use a back up from one switch, say a 3750G, and restore it to another 3750G?  Also, is there a way of editing the archived configuration so that I could change something small like the IP address?  This would allow me to writhe the configuration once, and then restore it to multiple, identical sswitches.
Marvin Rhoads
No, there's not any supported way to do what you're asking with CNA. Its configuration options are pretty limited - modify port configurations on a discovered community member and upgrade software.
The sort of thing you're looking to do is more of a feature built into Cisco Prime LMS (currently), Prime Infrastructure (2.0 - out next month), or by using Smart Install.
