Cisco PI Backup repository not writable Error
nabeelcse07
We have deployed Cisco PI 2.2 for one of our clients. Initially I was getting the error
Backup repository doesn't have enough space.
Then I did the following:
ncs stop
ncs clear all
nce start
after that i am getting the error backup repository not writable. Any suggestions on how to overcome this?
NA
11 Replies 11
Hi @nabeelcse07
Where is the repository? Is it on Prime or external?
-If I helped you somehow, please, rate it as useful.-
Hi Flavio,
Its on Prime.
NA
Can you access Prime via CLI and as root run the command:
df -h
I ll check this tomorrow and come back to you guys.
Thanku :)
I have faced a strange Situation. CPI Server is running but I cannot see it in Show CDP neighbour command and I cannot access it as well.
is there any specific Reason behind this apart from the Network side? I know I need to check the network connectivity as well and I checked its fine.
 - Prime is an app and not a switch ; it will not advertise any CDP info ; if you cannot access it; what happens then (in detail , tx) ?
M.
Hi Marce1000,
Actually I was referring towards Cisco PI Appliance. initially I was able to See it in Show CDP Neighbour Command. Now It has disappeared. Bu the Appliance is stil running.
NA
 - Check, if the Prime server is still reachable through an SSH connection if so log on using the admin account and issue : ncs status
M.
Its not reachable via SSH as well. I tried that.
NA
Hi Flavio,
Its on prime.
NA
marce1000
 - Check repository size using dir disk:/defaultRepo ;  backups can become quite  large, configure a repository via tftp or ftp for backup testing too ; check then, afterwards how much space a real backup takes and compare with the available space in the local repository.
M.
